Printer Essentials Canon Gpr-2 F42-1401-700 F42-3201-000 1388a003aa Compatible Copier Toner For Gp-200/210/2005/imagerunner 330/400/405 Logo
p
philip jeremiah Posted on Nov 30, 2013
E010 when I turn on my machine it shows the error stated
Jean
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 01, 2013
 Jean
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1192
Points
IR330, step 1- this Error is the main motor fails to rotate normally, does the main motor rotate until E010 turn on? if yes go step 5, if no step 2- harness wiring connectors around the main motor normal? if no correct the wiring, if yes step 3- does the voltage of J102-B12 on the controller pcb change to 0 VDC while the main motor is rotating?, if no replace main motor ( main motor driver pcb), if yes step 4-is there 24 VDC generated between J204-3 and J204-4 on the composite power supply PCB, if no replace the composite power supply PCB, if yes step 5 is the voltage of J102-B11 on the DC controller PCB about 5 VDC during WMUP? if no replace DC controller PCB. if yes step 6- Is there continuity of the harness between the image processor PCB and DC controller PCB normal J714-A14 to J113-A7 also 714-A16 to J113-A5 if yes to if no replace the harness if yes replace the DC controller PCB and the Image processor PCB.
Top Printer Essentials Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Printer Essentials Office Equipment and Supply Expert? Answer questions, earn points and help others
