Computers & Internet Logo
A
Anonymous Posted on Nov 26, 2013
Tripp lite kvm video problem - Tripp Lite Computers & Internet
2 Related Answers
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Sep 22, 2009
SOURCE: Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at:
www.ccl-la.com/badcaps.htm for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Anonymous
  • Posted on Nov 16, 2009
SOURCE: I own a Tripp Lite
I know it has been a long time, but I just experienced this same problem did you ever find a solution???
Top Tripp Lite Computers & Internet Experts
Steve Pack
Steve Pack
Gruber Power...
Gruber Power...
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
