Dymo LabelMANAGER 210D - Labelmaker - B/W - thermal transfer - Roll  - 180 dpi Printer Logo
Posted on Oct 19, 2017
Label printer problem
Hi
We have Dymo label printer 210D. I tried to print the label but it doesn't work. I changed the roll still not working.It seems the roll not turned. Could you advise me what should I do? If you have any further queries please contact Joanne perry
phone: 02 9964 6352
Email: library@acap.edu.au
Thank you for your help
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Dec 31, 2008
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
Anonymous
  • Posted on Apr 29, 2009
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Anonymous
  • Posted on May 05, 2009
SOURCE: DYMO Label/Writer is not printing after replaceing labels
DYMO labelwriters use patented labels, anything else would not be recognised by the system. For help - call DYMO support from your country.
DYMO support
Anonymous
  • 2777 Answers
  • Posted on Jun 25, 2009
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Mehandi Husain Suleman
  • 1654 Answers
  • Posted on May 14, 2010
SOURCE: is there an online instruction manual for this?
JUST GO TO FOLOWING LINKS YOU WILL GET ALL INSTRUCTION
http://global.dymo.com/img/compel/DYw_4SVxKUlFRhqWsk6u2-S5vyM4e91P.pdf
http://global.dymo.com/img/compel/ns92VcXCgzukCAryOt61J_1w2GU7P_X4.pdf
Top Dymo Office Equipment & Supplies Experts
jdthefixer
Arnie Burke
Arnie Burke
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
