Well. I just got frustation the last 2 hrs trying to fax using my workforce310 through Ooma (nopay/basic) service. Finally, tried the unconventional way and got it to work several time without any errors. I did the opposite of the instruction (1) turn ECM to On and V.34 to On. (2) dial with *99- (you can get the dash by pressing redial/pause button) and then the 10 phone digits, including the 1.
The only message I got after is that my fax has been sent in black&white because the reciver fax is not color capable. Isuspect error 0404 is to indicate this problem. Hope its help.
Reinstall the software driver for your soundcard to make it work. If you have the disc, just insert it and reinstall, otherwise, you have to download it from the internet.
vb-1 is a cubase virtual instrument this is where cubase was stalling, When i uninstalled cubase i went into the vst plugin folder and saw the folder vb-1 [virtual bass] I read the text file within and it told me to copy the dll files within into the active vst plugin folder. when i re installed cubase all was well. I have been using cubase for years and did not have this problem until i installed the e-mu 0404 pci card, or the audigy card
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8.
Using the Left and Right arrow buttons, change the last four digits
until they read 0000 for Region Free, 0101 for Region 1, 0202 for
Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11.
Press Standby again. Your player is now set to the region you
requested. If you find some titles do not play on the region 0 setting,
you may have to hard select the appropriate region.
Try company that made the sound card
http://www.zzounds.com/item--EMU8803 look there they may have a solution apparently there is a partition going around asking them (the Company) to revert back to the old standard of the card?
