Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax Logo
Ekera Teia Posted on Oct 31, 2013
Error code E002 - Canon 2 Ir3300 Ir3300i B/w Copier/ Network Printer & Fax
3 Related Answers
Lance Farrell
  • 50 Answers
  • Posted on Jun 10, 2008
SOURCE: error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Anonymous
  • 118 Answers
  • Posted on Jul 05, 2009
SOURCE: error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Marius Chiriac
  • 242 Answers
  • Posted on May 25, 2012
SOURCE: My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
1helpful
Konica Minolta BizHub C454e Color Laser Multifunction Printer. Error code C-E002
Question edited for clarity and add maker (what is is)'.
Question moved to model category.
Bizhub C 368 with error code E002
Copytechnet
https://www.copytechnet.com > ... > Konica Minolta
Sep 28, 2016 - Re: Bizhub C 368 with error code E002 ... That error has to do with the HDD, have you try to format the hard disk, upgrade or change it for a new.
bizhub C353 C-E002
Dec 22, 2016
Bizhub 423, Error C-E002
Feb 15, 2017
Error Code BIZHUB 601 C-E002
Sep 24, 2019
Electrical error code C-E002/E006 on bizhub 950
Aug 28, 2019
More results from www.copytechnet.com
More here
https://www.google.com/search?q=Bizhub+C454e+Error+code+C-E002
Canon imageRUNNER 2204. How to reset Canon 2204 error E002-0000?
Question edited for a lot more clarity and spelling of maker name.
Error Codes > Canon > iR1435 > Code E002 0000
Printcopy.info https://printcopy.info > code=E002 0000
Code: E002 0000; Description: Fixing assembly temperature rising error; Causes: The fixing assembly does not rise to the constant temperature within ...
How do I adjust cannon 2202 E002-0000 error and power adjustment.
Video help and test based help
Error Codes > Canon > iR2200 > Code E002-0000
PrintCopy .info https://printcopy.info > code=E002-0000
Causes: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty.
2answers
Error code E002
I googled: canon imagerunner 2022 copier error code e002
This appears to be the best and most informative: http://www.fortwayneprinterrepair.com/wordpress/2014/08/12/canon-ir-2200-2800-reset-fuser-error/
If not, try some of the others from the above search.
1helpful
2helpful
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
1helpful
Error code E002 cannon 6612 photocopier
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
