SOURCE: CANNOT SEND OR RECEIVE MAIL IN VISTA WINDOWS MAIL
Sir, this is a classic case of your computer not connecting to your Internet Service Providers mail server, its a common problem and not hard to fix. You may have it typed in correctly but the problem may be at the ISP's end. I don't know what solutions you were provided but try this one and if it does not work then you need to call your Internet Service Provider and demand a fix immediately.
Click on start>run> then type in "cmd". This will bring you to the DOS prompt. Type in "ipconfig /all" and write down your IP address and your gateway address so you can provide it to your ISP. If your IP address is 192.168.x.x then your DHCP is not providing you a private IP address. Regardless of what the IP address is, the only option for you is to do the following: At the DOS prompt type in ipconfig /release. Then type in ipconfig /renew. IP addresses are automatically provided by a Dynamic Host Configuration Protocol (DHCP). Once you release your IP address and receive a new one then the problem can no longer be fixed at your location,it is your Internet Service Provider that is causing your problem. Someone should have told you this long before you got the migraine..I apologize for the sub level service you have been provided by our company. Good luck and let me know how things turn out.
SOURCE: Trying to setup Microsoft Office Outlook getting
the problem should get solved by going to your email account settings (Tools > Account Settings > More Settings), and checking the "My outgoing server (SMTP) requires authentication" option.
SOURCE: I am trying to use
> I have done an email trace route under this account cbrown@gmail.com and this what comes up
RCPT TO:<cbrown@gmail.com>
550-5.1.1 The email account that you tried to reach does not exist. Please try
550-5.1.1 double-checking the recipient's email address for typos or
550-5.1.1 unnecessary spaces. Learn more at
550 5.1.1 http://mail.google.com/support/bin/answer.py?answer=6596 z11si13852608anc.1
[Address has been rejected]
RSET
> so this means this email address is non existent, or it was deactivated
either by the owner or Gmail itself on some reasons we don't know.
SOURCE: I forgot my password to
make sure that your email adress is correctly spelt with capitals and any of these .-_ also your password will need to spelt with the same way a computer is very precise with any pass words or email adress typings for security measures or
If this email program has the function of sending your password to another email adress you could open up a hotmail account which is free then get them to send your password to your new email adress
hope this helps
dont forget to vote
SOURCE: i have forgot my password
your have to provide the right answer for your private question on your gmail account. go to gmail.com and click forgot password - answer the security question
