SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
SOURCE: trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
SOURCE: Check paper size
Change the default setting for the paper size on your computer to letter. The paper size need to match on the printer and computer for it to work properly.
SOURCE: I have canon mf5700 says check paper size and only prints one page of several page job
Press that button "status monitor" on the left and you'll be able to cancel the current print/copy/scan
jobs. Just press that button then you can navigate with the "-" "+"
buttons from the right to select the
job you want to cancel. Then press button "ok"
After cancelling the print job, open the cover and close the cover.
the printer resets and the error message goes away.
