Computers & Internet Logo
Nex Stra Posted on Oct 22, 2013
Install autocad on Windows 7 - AutoCAD Autodesk Computers & Internet
3 Related Answers
Anonymous
  • 60 Answers
  • Posted on Jan 03, 2010
SOURCE: I am trying to install AutoCAD 2004 on my new
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Anonymous
  • 304 Answers
  • Posted on Dec 06, 2010
SOURCE: when I install autocad2004 in
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Anonymous
  • Posted on Jan 17, 2013
SOURCE: how to install autocad 2004
I had no issues installing AutoCAD onto a Windows 7 x86 Professional system. User is making and saving new drawings as well as opening existing drawings.
AutoCAD 2004 works fine on Windows 7 Professional 32-bit.
2helpful
2answers
How to install autocad2004 on windows 7
On window 7-32bit, you can install AutoCAD 2004 normally, but AutoCAD 2004 is not supported on window 7-64bit
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
1helpful
2answers
My autocad installer is autocad 2007 while my pc is windows 2007 when i install the installer it was a success but my problem now is the worksite wont appear it doesnt run
I've been searching around for a solution for my AutoCAD 2004, and have now found one - so I thought I'd update everyone on Fixya since I've always used the solutions and never posted! I used a tool called the Longbow Converter, it installed my AutoCAD 2004 on 64bit Windows 7 perfectly, the website says that it supports your version too - hope it helps. Nex
8helpful
When I install autocad2004 in windows 7 ,autocad can't run. untill now AutoCAD 2004 can't be compatible with a Windows 7 ?
2answers
How to install autocad 2004 on windows 7
Autocad 2004 is not compatible with Windows 7. Use a newer version.
System Requirements
For 32-Bit AutoCAD 2011 @
http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=13784795
6helpful
4answers
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
Top Autodesk Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
