Computers & Internet Logo
A
Anonymous Posted on Oct 09, 2013
Linux drivers serial - SuperMicro Computers & Internet
Christopher Smith
Level 2:
Champion:
  • Expert 261 Answers
  • Posted on Jul 03, 2015
Christopher Smith
Expert
Level 2:
Champion:
Answers
261
Questions
0
Helped
64073
Points
404
The first place is always the Debian Linux website, because most Linux packages are derived from Debian.
Serial video cable driver for linux
Hey Anonymous! Unfortunately, the SSU-100 Single RS-232 Serial Adapter is only 'officially' supported on the following Operating Systems:
Windows 2000, Windows XP, Windows Vista, Windows 2003
To the best of my knowledge, there is not a Linux porting of the drivers.However there is a Linux driver package for the Quatech ESU2-100 (see below)
http://www.quatech.com/ManualsDriversFirmware/Communication/serqt_usb2_2.6_1.00.tar.gz
I doubt they are interchangable.
1helpful
I have APIOTEK EC-0008 serial express port card RS 232 it is not getting installed on my dell windows XP enviornment what is the reason
have you installed drivers for the card, as windows might know what it is but it wont be able to use it till the drivers are installed click below onto what version of windows you have and download the drivers
EC-0008
Windows 98/M2/2000/XP/2003
Windows Vista 32/64bit
MAC 8/9/OSX
Linux RedHat 7.3/8.0/9.0
How to enable the serial port under linux(ubundu 10.04) tell me commands for what are all the to solving the problem: i need immd answer
Linux offers various tools. Linux uses ttySx for a serial port device name. For example, COM1 (DOS/Windows name) is ttyS0, COM2 is ttyS1 and so on.
Task: Display Detected System's Serial Support
Simple run dmesg command
$ dmesg ' grep tty
Output:
[ 37.531286] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 37.531841] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 37.532138] 0000:04:00.3: ttyS1 at I/O 0x1020 (irq = 18) is a 16550A setserial command
setserial is a program designed to set and/or report the configuration information associated with a serial port. This information includes what I/O port and IRQ a particular serial port is using, and whether or not the break key should be interpreted as the Secure Attention Key, and so on. Just type the following command:
$ setserial -g /dev/ttyS[0123]
Output:
/dev/ttyS0, UART: 16550A, Port: 0x03f8, IRQ: 4 /dev/ttyS1, UART: 16550A, Port: 0x1020, IRQ: 18 /dev/ttyS2, UART: unknown, Port: 0x03e8, IRQ: 4 /dev/ttyS3, UART: unknown, Port: 0x02e8, IRQ: 3
setserial with -g option help to find out what physical serial ports your Linux box has.
I am unable to install centOS 5.5 or openfiler to a supermicro server with an areca 1210 controller. The lofigal volume size is 200MB (the drives are actually 2TB each, but I carved out a 200mb part for...
http://www.areca.com.tw/products/pcix.htm
i think you must see this specification first, and then you will know why your centOS unabled to install areca ARC-1210 serial ATA controller, if you was see at that site, it describe that areca Software Drivers arrow.gif Windows 7/2008/Vista/Server 2003/XP/2000 arrow.gif Redhat Linux and SuSE Linux arrow.gif FreeBSD arrow.gif Solaris 10x86 arrow.gif UnixWare 7.1.x arrow.gif Netware 6.5 arrow.gif Mac OS 10.4.x/10.5.x/10.6.x (EFI BIOS support)
i hope this helpfull
please rate my answer
thanks
Want to make linux based driver for my MODEM
You can google that question and get lots of hints and tips but the bottom line is the device you are using is not considered a simple chipset device and therefore this is not going to be a walk in the park.
4answers
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Regarding driver
You are not alone. Most people that are using Vista can't get wireless drivers or dial up drivers to work even when they are marked as Vista compatible. If your notebook has a serial port I would recommend buying an external modem. Usually weather or not you have Vista XP or Linux an external modem will work that is hooked up via a serial connection but if the vendors of your laptop were too cheap to put in a serial port your out of luck unless you can find a PCMCIA or PCI Express card that has dial up and a vista driver. You need to know if you have PCI or PCMCIA. Now if this is a new laptop I would suggest you take it back to wherever you got it and contact www.mindblowingidea.com/ComputerRescue and have them give you a laptop that has the ability to connect to dial up.
Secondly Dial Up won't work with Vista correctly because Vista is full of DRM (Digital Restrictions Management) and Trusted Computing technology that use to be codenamed "Project Longhorn" back in 2002. This requires Vista to send and recieve information from Micro$oft at all times to make sure your not pirating music, using non registered Micro$oft software, or using a dial up modem that does not support DRM drivers lol :) . It says this in the Vista EULA. Now the above company Computer Rescue does not sell any Vista Computers. They only sell XP and Linux computers. I'm sure you would appreciate that a lot more.
Top SuperMicro Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Eric
ADMIN Eric
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
