karen roberts Posted on Oct 05, 2013
Keeps blowing lamp - 3M Office Equipment & Supplies
Chloe Z
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 07, 2013
Chloe Z
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
6046
Points
5
Don't touch the bulb with bare hands. grease from your hands will make the bulb blow out
Hello I have a RCA HDTV m50wh74xy1 problem is I keep having to replace the lamp,each time I replace it (lamp) it might last for 3 months I would like to no what is causing the lamp to blow out
This could be difficult to find but most likely a grounding/shorting issue. I would start by checking the power supply and the leads coming off of that.
On RCA HDTV wh74xy1 lamp blows out every three months
fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
2001 mustang v6 automatic convertible keeps blowing fuse #10 (park, tail lamps)
The fuse doesn't blow till you turn on the light switch? If it blows before turning on light switch, look for a short to ground between fuse box and light switch.
If it blows after turning on light switch, I believe they make a short finder tool.
1helpful
2003 nissan pathfinder blows tail lamp fuse
you got a wiring issue that keeps shorting out fuses find that and that should take care of everything else
1helpful
My benq projector keeps blowing lamps.
first, blow out any dust with canned air. dust keeps in the heat that the projector is trying to expell. next, don't buy cheap lamps from random websites. you get what you pay for. and make sure you have the correct lamp that the manufacturer states. also make sure there is sufficient space around the projector. the vents cannot be blocked. lastly, reset the settings to factory default. many times there is a low power/full power setting. the fans go on full on high power. there should be at least 2 fans. one for the lamp, one for the optical engine. may be one for the power supply. if the one near the lamp is not blowing much, replace it.
Fuse number 6&9 keep blowing under the hood.
No.6 feeds the park lamp relay and No.9 feeds the fog lamp relay and the daytime running lamp resistor.
They are basically 2 seperate circuits so I would suspect you either have 2 seperate problems or you have an add on accessory like maybe a anti-theft system that ties into both systems?
98 saturn fuse keeps blowing
most likey a incorrect taillamp bulb or mis installed tail lamp bulb.Or front marker lamp socket corroded.Good Luck
Dead lamp
The sensor is located on or near the lamp compartment on the back side. If your lamp keeps blowing it may be the lamp cooling fan not working. However are you sure the lamp is blowing? Press menu and device on the front control panel both in together for 5 seconds and see if the led blinks a two digit code, then let me know the code. Please respond to this same post.
Top 3M Office Equipment & Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
