Posted on Apr 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a konica cpp-500 with error code SC45-01 and can't figure out what needs to be fixed
  • 1 more comment
  • keyesracer5 Apr 21, 2009
    Still have the code, how would I center the belt?
    I just moved the belt a couple different ways and it still has the error. The belt doesn't seem to off center. It's not close to ribs on either side. Is there a sensor that could be bad? It don't look like the belt has any active steering.
  • keyesracer5 Apr 22, 2009
    Machine is connected to the network. We use windows XP, it was working fine, some one pulled the Belt Module out to show someone the belt and after sliding it back in we get this error.
Grand Canyon Tech
Level 3:
  • Master 3,869 Answers
  • Posted on Apr 22, 2009
Grand Canyon Tech
Master
Level 3:
Answers
3869
Questions
Helped
1344539
Points
12723
This error code is because the cart is out of allignment I got this before to and what I did was reallign the print head and it went away, now if it does not go away you will need to have it serviced, I know your trying to find a quick fix but if you tryed all the steps we been telling you pick the best answer and move along and give the GURU there good feedback or even the little money for at least trying to help you with your issue Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
pvc73
Level 2:
  • Expert 95 Answers
pvc73
Expert
Level 2:
Answers
95
Questions
0
Helped
24399
Points
249
Please mention how old it is. Does u connected it to PC? which OS u r using? Does any power problem or something happened before u got this error. It was working fine before?? please reply for giving u th ebest solution
Anonymous
Level 2:
  • Expert 315 Answers
  • Posted on Apr 21, 2009
Anonymous
Expert
Level 2:
Answers
315
Questions
Helped
120711
Points
973
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal.
If the code number back on again, then it was the transfer belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Top Konica Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
ADMIN Andrew
ADMIN Andrew
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
