Computers & Internet Logo
A
Anonymous Posted on Oct 03, 2013
Error code 0141 how to solve this error
5 Related Answers
ItWillBoK
ItWillBoK
  • 108 Answers
  • Posted on Dec 24, 2008
SOURCE: no bootable device
Error Code 0141 means no drive detected.
If that's your problem then you should take out the harddrive out and try it on another laptop or buy an external enclosure.
You can get them for $10
If it won't run on another computer that means the harddrive is bad but if it does run then it means you have a serious issue within the laptop componants.
fixyathing
jhun T
  • 341 Answers
  • Posted on Aug 11, 2009
SOURCE: Juice got spilled on my laptop, now when it starts
you should have stopped using it first...get the battery out and have it dry in an airconditioned room for several days...I know you can't afford that..water is a sort of conductor and it short-circuits sensitive electronics.
A
Anonymous
  • Posted on Nov 09, 2009
SOURCE: error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
imil
  • 19 Answers
  • Posted on Apr 18, 2010
SOURCE: error code 0141. how to fix on a ispiron 1525
replace the hard drive
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Jan 10, 2011
SOURCE: Computer won't boot-- Dell inspiring
Welcome to Fixya
This error message tells you the the computer cannot detect the Harddrive. You might need to open the computer and check all the cable connceting to the harddrive. Try to reset the cable. You might need to run a HDD test also to determine the problem. If everything is checked and you are getting the same error message then it is already time to replace the harddrive.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How Can I Fix Error Code 2000-0141?
The Dell error code 0141, also known as error code 2000-0141, is an error you might see on your Dell PC. ... Error code 0141 means that your PC can no longer detect your hard drive. No hard drive means no operating system and no data. No operating system means you can't use your computer.
Remove any CD/DVD from the drive and try again.
Check the correct hdd type and system is set within your BIOS settings. Check the hdd is set as first boot option.
Did you have spurious messages over the last few weeks ... if so your hdd has failed and you need a new one.
1helpful
My computer could not start
Confirm that the hard disk is properly connected and make sure the RAM is well fixed. As long as it was just a fall, any of these should solve the problem.
4helpful
Error 2000-146
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
2helpful
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
1helpful
Error code 0141. Msg: Error code 2000-0141. Msg: No drive detected.
This is caused by the intel chipset overheating.
Your drive is usually ok, but the chip controlling the drive is too hot to function properly. Try blowing your CPU fan out with compressed air, then start using a laptop cooler to keep it cool and this problem should go away.
1helpful
Error 0141 msg:error code 2000-0141
Juice got spilled on my laptop, now when it starts i get an error code 0141 No drive detected. what should i do now? Error 0141 Msg Code 2000-0141 No drive detected at start up : no bootable devices Help...
1helpful
2answers
No bootable device
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
