Limit is displayed on my grohe digital shower what does it mean
Limit message is when the output water set temperature can not be reached, this is normally when the incoming hot water to the shower unit is not sufficiently hot. Service code 20 is something else inside the unit that is faulty, it could be a number of faults. Try reset Power down unit and re-start, it will either say Wait or Priming, after that it should restart, hopefully it will work. If not, you could have a internal fault with: The mixer valve/motor, the flow control valve or motor, the flow sensor. If you have hot water from other taps, then the mixer valve/motor is the most likely fault. If you only have cold water only from the shower head with limit message it could be the Hot solenoid controlled valve is faulty. Good luck as there are no spares available!
