Cooktops Logo
Posted on Apr 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need new knobs
I need to replace old knobs.
Anonymous
Level 3:
  • Master 530 Answers
  • Posted on Apr 23, 2009
Anonymous
Master
Level 3:
Answers
530
Questions
Helped
189034
Points
1609
That's easy. locate the model number. Wright it down. Depending where you live you can call SEARS 18004694663 give them the model number and say you need the knobs they will order them for you and send them to your house. try this and let me know if this doesn't work i will give you a different place to go.
How do I replace knob on
With your fingers around and under the rim of old knob lift up gently. You will find a flat spot on knob shaft. Replace new knob on shaft , flat spot on flat spot. GOOD LUCK FRIEND.
Sep 25, 2014 • Cooktops
1helpful
I have a Chef 4 burner gas cooktop probably at least 10 years old. I need to replace 3 burner knobs. One works fine. Where can I find replacements? I live near Perth, Western Australia.
In the US, there is a parts distributor with locations all over the country. Their number is 1-800-482-6022. They have four of your burner knobs (part number 74001253) in stock in the Fresno, California warehouse. The cost per knob is $9.27 US. I can't say how much the shipping would be, but they use UPS and FED EX.
Good luck....and good day.
Flames too high Jenn-air CCG2423
Definitely cut your loses and get a cooktop with a warranty. That unit sat on the back shelf for a reason.......it didn't work properly.
Also, but a cook top that is compatible with the safety knobs they sell as child guards at places like lowes and home depot.
here is a link to show you how the child proof knobs work
http://www.associatedcontent.com/article/327577/childproof_your_stove_safety_1st_stove.html
Replacement Knobs for 60's Universal Chef- Waste King Universal
I have an old Universal Chef stove - we are replacing - it is probably a mid to late 60's - the oven pan is warped - otherwise it works fine - burners, knobs, grates etc. are good - willing to let go cheap - contact Chester Koch 573-898-5508 (Elsberry, MO)
Apr 24, 2009 • Cooktops
1helpful
Jenn Air model JED8430ADW
are you up for the job? you may need a new switch.(Part # 74009254)the origal switch is nla but this switch should work. If you attemp changing yourself make sure you turn off the circuit breaker to the range,
10helpful
DCS range igniter won't stop
Hey all ... I just had a repairman fix my DCS cooktop that was doing the same thing ... ignitor problem. He replaced it and it's good as new. (Cleaning also did NOT work for me.) It cost me $216 for the repair. If you can find the part, it's pretty easy to replace. Just take off the front knobs (be careful as there is a 'ring' inside the neck of the knob) and unscrew the front. You will need a special screwdriver - looks like a star - but just snip the plastic straps holding the original ignitor in place and put the new one on the same way as the old one. You should be good as new. REMEMBER TO TURN OFF THE BREAKER!!! I can't imagine it would take more than an hour (tops) 'cause it looked pretty easy.
Sep 01, 2008 • Cooktops
Six burner gas cooktop
My husband figured it out.....when we took the knobs off, I, of course, washed the area they had been sitting on, thereby spilling some water into the open part which contained the wires leading to the igniters.  A short time with a hair dryer sorting things out.
2answers
JennAir Elec Cooktop Problem
The selector knob having lose contact the elements are for full adjument , the wire connection are rust and corroded need to clean terminal of elements.
Fan Switch broke off Jenn-Air CVE3400 Radiant Cooktop
I am wondering if you just need to replace the knob then perhaps you don't need to take much apart.
Is this a knob that has an allen screw in the side that unscrews to let it come off or is it a friction fit.
If the knob is so small that you can't get it off some times wrapping a thin rag around it gives you the way to tug it off. If it is the whole switch you are fixing then I see why you need to take lots of things apart. If found the installation manual online and that might give you a clue to how it is installed in the counter to take it back out if you need to get to the insides. I am not sure what you need help with so please let me know more if this was not enough.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=CVE340&siteCd=JA_EN_US
Dec 12, 2007 • Cooktops
Top Cooktops Experts
ADMIN Andrew
ADMIN Andrew
gerbee gomez
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
