rebecca grace Posted on Sep 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a scientific notation button? so that I can type 3*10^6
k24674
Level 3:
  • Aurora Elect... Master 8,093 Answers
  • Posted on Oct 19, 2013
k24674
Level 3:
Answers
8093
Questions
0
Helped
4761499
Points
21601
Look for a key marked EE, EXP, or *10^x.
To enter 3*10^6 you press 3 [EE]6. When using the Enter Exponent key, no 10 should appear on your display.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Aurora Elect... Master 102,366 Answers
  • Posted on Sep 22, 2013
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10724326
Points
622696
The EXP button, just above the 7 button.
Scientific notation on BD - 107i calculator?
Of course it is possible!
There seem to be many ways to do this on this calculator.
Assuming we cannot do scientific notation, we can always do
6.02 x 10 ^ 23 / 3.01 x 10 ^23. However, we have to put brackets in to get BEDMAS to work correctly!
6.02 x 10^23 / (3.01 x 10^23) - for the 10^23, type 10 then the y to the x key and then 23.
Using the scientific notation, we can type in 6.02 EXP 23 / 3.01 EXP 23.
Good luck with your chemistry test tomorrow!
Take care,
Paul
How to plug in exponents on sharpe EL 501X calculator
Type in your base and then press the button that says y with an x as an exponent (last row of the small buttons, second from the left). and then type in your exponent.
I need to know how to divide, mutiply, add, and substract in scienctific notation on my Casio fx-300ES
The "problem" is not how to calculate with numbers expressed in Scientific Notation but how to enter a number given to you in scientific notation. Once the number is entered you do not have to do anything special. If you have to multiply it use the (x) button. to add it use the + button, etc.
How to enter a number in scientific notation.
Type in the mantissa (example 6.022)
Press the [X10^x] at the bottom of keypad.
Enter the exponent (example 23)
with this example you will have entered Avogadro's number 6.022x10^23
Other example
1.6 [X10^x] (-) 19 enters the electron charge in Coulombs. The exponent is negative that is why you press the change sign key (-).
1helpful
I have a TI30XA calculator and want to know how to multiply numbers using scientific notation. I have learned how to enter a number (e.g., 1.5 x 10 -6), but when I try to multiply it by something (e.g.,...
Press 2nd [SCI] to switch the calculator to display all results in scientific notation. The results are the same whether you do it in scientific notation or not, it's just how the number is displayed.
1helpful
Is there a button i can press to put a large number in scientific notation?
Not a single button, no. You can press MODE down-arrow down-arrow down-arrow down-arrow right-arrow 2 ENTER to switch to scientific notation, then 2ND ENTER ENTER to repeat the previous computation.
1helpful
I can't solve negative scientific notations. If I type 1x105 I get 100000 when I press the solve or = button. But if I type 1x10-5 it gives me the same number
You need to use the (-) key in the far left column to enter negative values. Not just for exponents, but for all negative values.
What button is the scientific notation button i lost the sheet
To enter powers of 10 as in scientific notations use the EE key.
To enter 13x10^6 type in 13 EE 6 =
For a manual here is the link
5helpful
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
1helpful
Trying to get calculator to display in scientific notation
Press the [SHIFT][MODE] to access the (SETUP) screen. -See the screen capture below. Press [7:Sci] to select the output display format to be Scientific.
You will then be prompted to key in a number between 0 and 9 to choose the number of decimal digits.
If you do not want fractions nor radicals set the default Input/Output format to LineIO.
To do so press [SHIFT][MODE][2:LineIO]. After that perform the steps given above to select Scientific format for the output.
26helpful
HP 12C went into scientific notation and will not come out of it
To exit the scientific display format press the [f] key followed by the number of decimal digits you want.
Hope it helps.
Top Aurora Electronics Office Equipment & Supplies Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
