Posted on Apr 18, 2009
Mini disc error code?
Yamaha mini disc mixer. keep getting error, disc error 80. manual says scratch on disc. replace. I got 2 new, and it still reads the same../??////???? this product was not in the list of products. so picked one...
5 Related Answers
Anonymous
  • 624 Answers
  • Posted on Jun 30, 2008
SOURCE: Tapco MIX60 6-Channel Mixer
It does not appear to have a crossfader
Check this link for a closer look at the mixer. You can click the "larger image" link and get a really good look at it. Unless one of the knobs are a crossfader, but I always seen sliders as a crossfader. At least you can see it better here.
http://www.bswusa.com/proditem.asp?item=MIX60
Anonymous
  • 74 Answers
  • Posted on Dec 22, 2008
SOURCE: YZ parts
First you know that it's bored 30 over, now you need to remember what kind of pistion that was installed. Once you find that out it can be ordered on line.
Anonymous
  • 118 Answers
  • Posted on Nov 03, 2009
SOURCE: I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Anonymous
  • 88 Answers
  • Posted on Apr 26, 2010
SOURCE: Yamaha 5 disc changer. Will not read CD's. Picks
sound like lens problem. . use lens cleaner to clean good luck!
Top Yamaha Audio Players & Recorders Experts
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
