Cuisinart BFP-703 SmartPower Duet Food Processor Logo
A
Anonymous Posted on Sep 11, 2013
On light blinks and won't start - Cuisinart BFP-703 SmartPower Duet Food Processor
Kitchenaid food processor KFI 1325 brand new first use and won’t turn on
Make sure you have the bowl, lid and sometimes the pusher assembled correctly. If everything is not correct it will not activate the safety switch to allow it to start up.
My magimix 5200 won’t Turn on, I have checked the fuse and changed it and it is dead. Do you you think it is the motor ? And is it expensive to fix.
Hi, if it is the motor, (sounds like) then yes it is expensive to fix. You may be better off getting a refurbished one. :-)
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
I press a button n it blinks then all the buttons start blinking and the motor never starts.
The motor is most likely open circuit. Solutions are going to be either replace the motor OR if the thermal fuse on the windings is blown you will need to get one of the same value and replace it. The value is written on the fuse and it is under some fibreglass tape on the field winding with the aluminium clip around it. You need to remove the motor completely to do it.
2helpful
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
4helpful
I can't start my brand new cuisinart 14 cup model I have it plugged into a good power source, with shoot, rod and blade in place. It won't power up! Please help!
Hillary, I have the same problem. Do you think these are the edsels of the food processors. I paid almost $200 for mine, haven't ever used it since I bought it last year. Have you resolved your problem>
I am missing blades and slicers for a 3000 series.Do you stock these
cannot release bowl, tried turning to release won`t turn!
5helpful
Food processor
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Top Cuisinart Food Processors Experts
Rommel Balcita
vince
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
