I have a an adidas mans watch and when i went to replace the strap the assistant told me there was a recall on that model because of the strap breaking because of the design .Can you help me it is a CS1200MF
SOURCE: Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
SOURCE: Watch strap adjust
Not all watch bands are adjustable. If yours is, you will see the links are connected with tiny pins. Any store that sells watches will have the tool to remove links. Some watches require a special tool, those need to be adjusted at a store that sells that brand.
SOURCE: How do you set an Adidas Watch (Women's ADH6051)
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ADIDAS watch manuals. Rate me, please
SOURCE: How do I shorten my Ice watch strap?
mcdevito75 here, I imagine you mean a Band (metal) they can be shortened by removeing links from the band itself, you"ll need a specific tool called a link remover tool. they are available on ebay. However by the time you get the tool and the time to do the work, and if you don"t do any work on watches, the best bet is to look for a small watch repair shop in your area to remove these links. Hold onto the removed links for later replacement. If it"s a Strap (material) on your watch, say, leather, rubber etc. simply cut the excess strap at an angle with scissors.
