Need to unlock my samsung memoir
If you're looking for the unlock code to take off the restriction from your phone (aka use another sim card in it), you have to contact your company (T-Mobile) and request the code.
You will need your serial number, which you can find by dialing *#06# and also a valid email address.
If you are just needing your default pin code, it is normally 1234. Stop if you get to the "pin blocked" screen. You'll have to contact customer care if that's the case.
Good taste on the phone by the way:)
I know some companies make the code the last 4 digits of your phone number, have you tried that?
SOURCE: i forgot the phone lock password for my Samsung Memoir
Only way to reset it is to flash your phone. Search internet for flash files and flasher. After flash your phone will be set to default one!
SOURCE: forgot phone lock code
A lot of sites do unlock but there is this site I used couple of times and it pays best since I've been unlocking phones.
You get full money back guarantee.
Visit http://www.mobileunlocked.com/index.php
and just follow the site prompt.
Good luck and remember to rate this solution.
SOURCE: I need the code to unlock my samsung memoir from
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
