SOURCE: restore factory settings
what i would do is go into dos. If you cant get into dos find a windows 98 setup disk 3.5" this will have the dos files that will allow the computer to reconize a generic cd rom. This should allow you to get your recovery disk working. Your software problem could of created a firmware problem also. Not reconizing the cd rom. This solution will provide the basics to get your cd rom loading the recovery disk for you. If you have questions or more problems feel free to contact me and i will take you through it step by step
SOURCE: need to restore acer to factory settings
contact acer you can get there number from the website and they will let you purchase a restore disc for 15bucks
SOURCE: I want to restore my Acer Aspire M1100 desktop
You'll have to use your recovery disk to set it back to factory, unfortunately most recovery disks give you little or no options for which software is to be reinstalled. The only way to install windows without any of the extra software that your computer came with would be to take a standard windows installation disk and install through that. Afterwards you would have to manually install all the driver software.
Alternatively, you can install with your recovery disk and use the add/remove software feature in the control panel to remove any programs that you do not want, just be sure that you don't remove any software that is a driver for any hardware devices.
Hope this helps, get back to me if you need any more information.
SOURCE: I had a bad virus on my desktop (model M1100) and
if you want to restore it and remove the virus, u need to reprogram your mobile
SOURCE: I forgot my e-recovery password, no recovery disks...
Don't you have created the password Recovery disk early?
If you do, you can sign into safe mode and recover the password.
If you don't have the password reset disk. you have to take use of the 3rd party utility,
Windows Password Recovery 6.0 is highly recommend. It is fast and easy to use.
