If you cannot find a replacement part for a fan then do try Ceiling Fan Direction website. You might get a complete fan at the price of replacement part.
http://www.ceilingfandirection.com/ CeilingFanDirection CeilingFanDirection
That's not the Hunter part #. Call 1-888-830-1326 with your fan model #
SOURCE: Light not working-hunter ceiling fan need part number 85112-01?
"Google" ----"replacement parts for ceiling fans"
there are dozens of sites that may be of help.
SOURCE: How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
SOURCE: I have a hunter ceiling fan. The motor works fine,
NO YOU DO NOT !! there is a little black box on inside of fan that controls the lights, its a ( watt governor ). just remove this black box and wire directly to the lights. problem should be fixed !! have a good day !! this is another goverment quick fix.
SOURCE: hunter 'lodge' ceiling fan w/light:
if problems with the light blinking, remove watt governor inside fan, for lights. and wire the lghts directly. this should fix problem. the watt governor is a small black box to reduce wattage on the lghts. just remove it and wire lights directly. have a good one !!
