The solution given by yoopersab is wrong. That solution is for a USB camera.. not for an IP camera that you have.
To setup the IP camera, do the following:
1. Install the D-Link installation software on your PC
2. Connect the camera to a network cable directly connected to your router/switch
3. Run the D-Link software and it will show you the camera is detected.
4. Click on the camera to change the network settings and other settings as you see fit.
5. If you need wireless connectivity, configure this also then remove the network cable.
6. Turn off the camera, make sure you have plugged in the wireless antennae and turn the camera back on.
You should have wireless connectivity after that. Make sure you enter the proper values according to your configuration.
One last thing, if you need to view your camera from outside your home, you need to setup port forwarding in both your modem and router.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
After you get your camera installed properly, DO NOT unplug it from the USB port as it will cause
the drivers to be corrupt and render the camera unusable till reinstalled it properly.
Hope this helps. Bud
