What brand of motherboard ?..
http://www.youtube.com/watch?v=-gKzoQ2RtKU
Soldering Techniques
http://www.youtube.com/watch?v=KYoGu4FmI8g
Solder USB Port on HTC G2
This might give you some sort of an idea
be very careful not to touch any other parts on the motherboard with the soldering iron.
WARNING: Before you start
troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php
- rules
Only work inside the computer case
when the power has been switched off and disconnected. Never open the power
source.
Some of the below steps
recommend removing physical parts within the computer.
While in the computer it is
highly recommend that you be aware of ESD and its potential hazards
SOURCE: usb port on lacie has become detached and fallen inside
This procedure is to extract the drive from the case..
1. The case is useless, dispose of it when you've extracted the drive. Attempting to reuse is pointless and could only cause more damage.
2. Make sure you disconnect ALL cables to the drive before you begin this.
3. You will need to be gentle as and shock or impact to the hard drive may render it useless, which would be unfortunate, considering it sounds as if the case is the issue, not the drive.
4. When choosing a new enclosure, go aluminum, and with no internal fan or psu. This just makes the environment hot and severe.
They cost slightly more than what is on the consumer market, but i use and recommend
Wiebetech TT4 or TTXE models, depending on whether the drive is PATA or SATA.
So to answer your question...
Yes, with a flat head screwdriver ( like a jeweler's ) and the drive on a book on its topside down. You can gently pry the bottom housing off about and inch from each corner. Upon prying up, you'l see the little slotted hole. There should be 4 metal fingers on both sides of the drive, screw in 2 on each side. Then remove the plastic contact guards, and gently pull up at the led light ( the power cable for the light should be running down the middle and is usually red or green. Once youve removed that, gentley put your hand on the drive, and with your other hand, flip the entire enclosure over. The drive should lightly fall out of the enclosure and into your hand......minimizing shock or movment of the drive, these things should be handled like babies..never shake.From here grasp the drive itself, and you will notice 2 cables binding the drive to the enclosure.The first is the data cable know as IDE or PATA and looks like a ribbon- more often yellow- second is the power cable known as MOLEX. The molex cable should be 4 wires..2 black, 1 yellow, 1 red. Ofcourse, be gentle when removing both Cables, as to not exert to much force so that it goes flying when its released. Once youve separated the 2, youll see that case for all its glory, or not. It's really a soda can with the cheapest components internally. Once the weight of the drive is out, there nothing to the box.
If you have any hesitation or addition questions before you begin, please ask here.
SOURCE: WD External Hard drive does not work no power to it
External drives tend to use power supplies at 12V DC and 1 amp or just a little bit over. You could read the output of the power supply with a digital volt meter. If you have power and the enclosure still refuses to turn on, you could buy another enclosure, another power supply, or just a naked USB to IDE adapter and pull the drive out of the existing enclosure.
Chances are, the drive you get out of the housing will never be going back into that case.
SOURCE: I have a LaCie external harddrive that refused to
i too have had this problem and it generaly means it is broken. sometimes things can be done but it is very costly
SOURCE: my power and usb cable connections broke loose
It can be repaired just use a low heat soldering iron, and use heat sink clips, so that the heat will not
transfer and burn other components. make sure all power cords are removed from the board. use a
wrist ground strap to dissipate any static buildup that can damage components on the board. good luck!
