Is the map checked (turned on) on the map menu screen? Find the map screen and then the map info button. Is there a map listed there and is it check marked?
ENGINE MISSING AT ROAD SPEED CAN BE MANY THINGS.FUEL FILTER CLOGGED FAULTY FUEL PUMP. OR BAD FUEL.BAD SPARK PLUGS AND WIRES.LOW OR UNEVEN ENGINE COMPRESSION.FAULTY IGNITION COIL.BAD DISTRIBUTOR CAP AND ROTOR IF EQUIPPED.VACUUM LEAKS AND LEAKING EGR VALVE.
Sounds like a load miss. Chk plug wires for deterioration and or cross firing. Wires should not cross over each other. Worn plugs load wires causing increase spark out put increasing cross firing potential
