The E5 message is displaying with no means to get it off or getting the machine working. Any ideas I have tried some of the other solutions.
How to check speed sensor and cybex 530t pro
Follow this steps and fix it. God bless you
The power up test sequence has detected a key in the
operated condition. The power up test
sequence is performed every time the unit is turned on
(powered up). This test is performed
because a permanently stuck key will inhibit the
correct operation of the unit.
Possible Causes
1. A key on the display housing is permanently stuck
in the operated condition.
2. One of the upper PCA's keypad interface chips has
failed.
3. Liquid (perhaps perspiration) is present on the
surface of a touch sensitive display.
Possible Remedies
1. Remove the keypad connector cable from the upper
PCA. Restart the power up sequence, if
the ERROR 5 is no longer present, the keypad is the
cause. The keypad is typically part of
the display housing. Replace the display housing to
correct the problem.
2. Remove the keypad connector cable from the upper
the ERROR 5 is still present, the upper PCA is the
cause. Replace the upper PCA to correct
this problem. Most upper PCA's are provided without
software. Therefore, the software (chip)
must be removed from the upper PCA being replaced and
re-installed on the replacement
upper PCA.
3. Wipe the surface of the touch sensitive display
clean of all liquid. Restart the power up
sequence, if the ERROR 5 is
no longer present, the liquid was the cause.
Testimonial: "After trying this the machine show E6 when lead disconected and then returns to E5 when plugged back in."
SOURCE: T9350 Getting error code E5
This
just means that the elevation is out of range. It probably lost its
signal when you moved it. The way to fix this is to recalibrate it. The E5 error code indicates the electronics on your treadmill require calibration. Recalibrate the treadmill to fix the problem.
SOURCE: I have a vision T9500
hi, With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START. (The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen) If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module. OK
Try AUTO-CALIBRATION first. For that do the following.
