Sierra Overdrive Pro 3g/4g Mobile Hotspot For Virgin Mobile Logo
A
Anonymous Posted on Aug 01, 2013
Error code 900 - Sierra Overdrive Pro 3g/4g Mobile Hotspot For Virgin Mobile
2helpful
2answers
I am getting a 900 firmware error notice
A 900 Firmware error means that something has corrupted the code on your printer.
The easiest way to fix this is to go to www.lexmark.com > Support > Downloads and download the latest firmware for your printer.
2answers
Error code 900 Lexmark c544dn network printer
900 errors usually point to fuser or fuser related component failure.
Please have the printer serviced.
2answers
Problems with the c760 900 service rip software error, can you help?
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: http://bit.ly/c2xr1t. There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
1helpful
2answers
900 service rip software error on our Lexmark Optra S1855 what does it mean? How do I fix it?
These errors indicate an unrecoverable engine software
error. Replace the engine board is the only solution
4helpful
2answers
When I turn on my lexmark x204n it gives me a 900 firmware error how can I get rid of it and what does it mean?
Don
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
2answers
900 service RIP software error on boot-up
removed memory off the system board restarted printer. came up to an error no memory found.
powered down and reinstalled memory on board in a different slot and restarted unit...
NO ERRORS......
1helpful
2answers
900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
7helpful
4answers
900 service error with lexmark printer
OK, a couple of things... Some earlier Lexmark units had code on both a RIP board (raster image
processor) and an engine board. In this case, the code would have to be reloaded into both
boards. Fortunately, this can be done even if the printer will not boot to a ready state. However, if
this has already been done sucessfuly, the problem may well not be the printer but rather something
in the data stream. To confirm this, remove any and all data cables and reboot the printer. If it comes ready and you can print all the internal pages including the network config pages, then it is likely the
problem is the data stream. One must be careful when the printer is controlled by a print server
because the end user may not have control over the print que. If a corrupt or printer incomprehensible
job is stuck in the que, the printer will go to a 900 condition as soon as the network interface
initializes. This will continue until the print que is cleared.
Hope this helps...
Sean.
Top Sierra Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Anonymous
Are you a Sierra Computer and Internet Expert? Answer questions, earn points and help others
