SOURCE: DELL Latitude D510
unmountable boot volume means that either your system is corrupted, your boot.ini is damaged, or your boot sector is corrupt. Try this:
"You can boot to the XP cd and when you see the Welcome to setup press the letter R
You will get a dos prompt
Then type "chkdsk /p" without the quotes and hit enter
When that is done type "fixboot" and hit enter
"Y" and enter at the prompt
Then type "exit" and hit enter
The system will now reboot into Windows"
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
SOURCE: Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
SOURCE: dell 6100 laptop blank screen
Boot into the one that says, "Safe Mode with Command Prompt"
Once it's done it will ask for an admin password (sometimes) if it does just press the enter key, unless you set the Administrator password to something else.
Once your past that.
Type:
chkdsk /r
a message will pop up (sometimes) saying something about the disk being locked, blah, blah, blah.
Just press the Y key, then enter.
Restart the computer.
Let it do it's thing ( disk check will appear)
Let me know if this solves your problem.
SOURCE: Having problems restoring my acer 5100 notebook.need help please!
Hi there.
Log into Windows and press Acer Empowering Key to launch, you can use that utility to restore the system.
If you have a pqservice partition but alt f10 does not work there is a
file called mbrwrwin.exe and rtmbr.bin which is needed to install the
acer missing magic code all you have to do is type the following on a dos prompt. mbrwrwin install rtmbr.bin it adds the file to a slot
Once you have done that reboot the computer and wait it takes a while
to restart, it then it seems to find new hardware (dont know what it finds)
then do a reboot and then you can alt f10 to your hearts content.
Good luck and thanks for using FixYa!!
