My GE dehumidifier will run for a few hours, and then go into P1 error code, will defrost for 30-60 minutes, then work again for a few hours, then go back into P1. We have never had this problem until this year. We took the filter out and cleaned it, wasn't bad at all. Any thoughts?
SOURCE: GE AHH40LH DEHUMIDIFIER
Either the humidistat is bad and not letting the unit cycle off, there isn't enough humidity in the air, or the condensor coils are too dirty.
SOURCE: My GE Dehumidifier fan is working fine, but the
a dehumidifier can only remove water from the air that is humid. have you checked the humidity of the room ti see if it is high or low?
In the winter the average room air is sometimes so dry that one have to add water with a humidifier.
did you check if this is not the case?
