Follow this instruction and reset. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
Locate the reset switch on the underside of the treadmill
console. Usually the button is large enough to trigger with a pencil
eraser or Q-tip. Plug the treadmill plug back into the wall. Use the
Q-tip to press the reset button. It may be necessary to hold the reset
button down for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the reset button one more time with the Q-tip. "CL21"
should appear on the screen. Press the enter key. The display will
change again and show "CL22." Keep pressing the enter key until the
numbers cycle through to the number "CL26." Press enter one more time.
The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on
the screen. When this happens, press the start/stop key. Making sure to
keep well away from the tread, press enter to start the treadmill. The
treadmill will start on its own. The treadmill will stop on its own
after a few seconds. When it stops, press the power key two times.
Remove the safety key and put in a safe place. Your treadmill is reset.
Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
