Computers & Internet Logo
A
Anonymous Posted on Jun 30, 2013
Function keys
Using the D-link to share a monitor, keyboard, mouse, speakers between work and private PCs. However, my F-keys do not work. I use a Microsoft 4000 ergonomic keyboard. Any ideas? Cynthia
5 Related Answers
daverh
Dave Harris
  • 117 Answers
  • Posted on Oct 15, 2007
SOURCE: KVM GCS1734 with microsoft wireless mouse/keybrd 4000
The MS keyboard & mouse receiver is effectively a USB hub with two devices connected to it. So, plugging it into the keyboard socket on the KVM switch may well work, depending on how that particular switch implements USB. If it just passes things through, it should be OK. On the PC side you should only need to plug in the USB cable from the switch's keyboard port.
Anonymous
  • Posted on Jan 21, 2009
SOURCE: Problem with KVM switch and Vista
Your switch box will need auxiliary power.
Anonymous
  • 2923 Answers
  • Posted on Apr 06, 2009
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Anonymous
  • Posted on May 23, 2009
SOURCE: using KVM-121 with 2 monitors
You should be able to -- the KVM switch would just switch inputs for the monitor, but since your two monitors would be plugged in directly to your computers, the switch wouldn't actually be affecting your monitor inputs.
Just make sure to plug your monitors directly to your computers and not use the switch.
Anonymous
  • 31 Answers
  • Posted on Jan 09, 2010
SOURCE: I am trying to run two pcs using an EDIMAX 2 port
i don't ?
Top D-Link Computers & Internet Experts
Narseman
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
