Jensen SC-570 Remote Control Logo
A
Anonymous Posted on Jun 30, 2013
Codes for programming remote
I'm trying to program my Jensen SC-570 remote control to my general Electric television I can't find the codes for the tv
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jan 30, 2008
SOURCE: programming code for remote control jensen jr321
I am not 100% positive that the JR-321 is supported in the 300 series but.
Jensen JR300 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps!
DETHMetal666
  • Posted on Feb 09, 2008
SOURCE: Jensen SC-570 Universal Remote Control
I have a suggestion , Stop posting complaints and until you find out how stop coming here and reading tese stupid ass comments that lead you no F**King where
Anonymous
  • 236 Answers
  • Posted on Apr 04, 2008
SOURCE: codes
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
Turn on the component that you want to set up.
Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
Release the component key.
If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
Press "0" - "9" The green light will blink as codes are sent.
As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
If that doesn't work, you can get a list of codes from HERE that should work!
Anonymous
  • 236 Answers
Try the auto code scan:
Anonymous
  • Posted on Nov 05, 2008
SOURCE: I'am trying to program the jensen sc-340A to my sanyo television.
my t.v is a sony trinitron model no. kv 1972r .the t.v has lock out ch.3 and more ch.in it help
Top Jensen Televison & Video Experts
Sudeep Chatterjee
Sudeep Chatterjee
Herb Box
Herb Box
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
