SOURCE: 1 way and 3 way dimmer switches
The answer to your question depends on the manufacturer and type of 3 way dimmer you are using... generally you can use a 3 way switch as a single pole switch, but whether or not this holds true with the dimmer you are using depends. Let me know what you are trying to acomplish and model numbers mfgs of what you have and I'll try and help
SOURCE: So, with that being said, if we assume the white
The most likely candidate is the white wire. In a standard residential installation, the white wire is often the neutral connection - and wiring the dimmer hot to neutral will cause exactly what you described.
However, often times the white wire is instead a traveller wire being run to the switch from the fixture (which, it sounds like that's what you were assuming) - in which case, the other likely candidate would be having a loose power connection coming in contact with ground. Sometimes this can be a loose screw or, as you describe, a loose wire.
Your best choice would be to install a standard 50-cent light switch first. If you connect it together and it works - then you know a connection came loose and made a bad contact - so then you can try using another dimmer. If you connect it and the breaker trips - then you know you're using the wrong wires/connections.
