Avanquest Fix-It Utilities 9 Professional for PC  Logo
Anonymous Posted on May 25, 2013
Program I just recently purchased Fix-It Utilities from an Office Max and when I tried to follow the instructions on the manual and download the program, it does not open! The program downloads but it will not stay open after I click on it and try and analyze the computer! I have doen eveything the manual has asked to do, I have tried downloading it and removing it from my computer numerous times, I have restarted the computer and have done everything I can think of but it still won't open and work! Why?? Please help! This is so frustrating!
Brian Sullivan
Level 3:
  • Avanquest Master 27,725 Answers
  • Posted on May 26, 2013
Brian Sullivan
Avanquest Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
Fix-It Utilities is a program by Avanquest that is marketed as an all-around computer protection and enhancement tool.
Fix-It Utilities scans your computer for potential problems and fixes them automatically. Additionally, it monitors your computer in real time to alert you about hardware and software issues before they can cripple your computer.
If you are looking for a utility to handle your computer maintenance for you, Fix-It Utilities is one program that you might consider selecting.
Double-click the downloaded program file if you purchased the digital version of Fix-It Utilities directly from Avanquest.
If you purchased the boxed retail edition, insert the installation disc and allow a moment for the Fix-It Utilities installation program to load.
Click "Next" when the Fix-It Utilities Installation Wizard appears.
Read the terms of the Avanquest license agreement carefully before continuing.
If you are willing to abide by the terms, click the "Accept" button to continue.
Enter the name that you would like to register Fix-It Utilities under, and then type your 24-character product key exactly as it is shown in the product packaging or the email sent by Avanquest when you purchased Fix-It Utilities online.
Click "Next."
Select the radio button labeled "Complete" to install all of the features of Fix-It Utilities, and then click "Next" twice.
The installation utility begins copying the files for Fix-It Utilities to the hard drive.
When this process is complete, the installation utility displays a screen with four check boxes.
Use the four check boxes on the screen to indicate whether you would like Fix-It Utilities to check for and install updates automatically, whether you would like the program to make snapshots of your system for recovery in the event of a problem, whether you would like the program to monitor your computer for malware and viruses and whether you would like the program to scan your email.
Click "Next," and then click "OK" and "Finish."
Fix-It Utilities is installed.
If you used the check box to configure Fix-It Utilities to check for updates automatically, the program begins scanning the Internet for updates immediately.
http://www.avanquest.com/USA/software/fixit-utilities-9-professional-114420?gclid=COGnn7CYvZ0CFQgtawodB3Hjpw
if you still have no luck there are freeware alternatives on the internet as well as the chkdsk utility.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360amigo-system-speedup-free/3000-18512_4-75206713.html Improve your PC performance and fix errors.
5 Related Answers
EL FADIL MOHAMMED
  • 423 Answers
  • Posted on Jun 10, 2009
SOURCE: I cannot uniunstall fix it utilities 8
try to remove it with your uninstaller 2008 or revo uninstaller or you can restore your system hope it works plz rate it fixya if its helpful
Patrick Kirwan
  • 30 Answers
  • Posted on Sep 09, 2009
SOURCE: system suite9 cant be uninstalled
Go here
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Then beside the world globe you'll see
Download Revo uninstaller freeware click this download it
Save it
go to where you saved it
now double click it and run / open it
when it installed you can safely remove the programme that you want but use Advanced mode and it will delete everything to do with the programme
Anonymous
  • 583 Answers
  • Posted on Feb 16, 2010
SOURCE: Tried everything to uninstall Avanquest Fit-It
Go into the the Program Files directory of your C drive. Look for Avanquest or Fix-It directory. Look for unwise.exe or uninstall.exe or something similar. Double click that and follow the prompts. If that doesn't work, please let me know and I'll do some more research.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 19, 2010
SOURCE: I've downloaded Fix-it 10. It won't install until
Well in that case go to the Program Dir find the Folder it is in, and simply Delete the files, delete them all, then remove delete that Dir, Now try a reinstall. Either that or in that Directory look for the uninstall exe file and double click on that and try that way first... else remove them all.
Azrael SRL
  • 11800 Answers
  • Posted on Sep 02, 2010
SOURCE: I purchased a copy of
Boot in safe mode, search the entire hard disk for Avanquest or Fix-it files and folders and manually delete them. Then boot normally and remove the Fix-it 8 entry from the Add/Remove Programs list using this
http://www.gaijin.at/en/dluic.php
Finally run a good registry cleaner like
http://www.eusing.com/free_registry_cleaner/registry_cleaner.htm
After that you will be able to install your new program.
Top Avanquest Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Tim Hofstetter
Tim Hofstetter
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
