AsRock Support > AlivenF6G-DVI Motherboard > Main Support page,
http://www.asrock.com/MB/overview.asp?Model=ALiveNF6G-DVI
In the list on the left hand side, click on CPU Support List
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ALiveNF6G-DVI
The AMD Athlon 64 X2 5800+ CPU, (Processor), is part number ADA5800IAA5DO.
Operates Up To a maximum frequency rate ('Speed'), of 3.0GigaHertz, has two L2 cache's of 512MegaByte, and uses the Socket AM2 CPU socket.
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_64_microprocessors#.22Brisbane.22_.28energy-efficient_65W.2C_G1_.26_G2.2C_65_nm.29
In the CPU Support :List it is not shown.
This is ONLY because the Athlon 64 X2 5800+, came out way after the CPU Support List was compiled. NOT because it isn't supported.
No, I have to amend that,
http://forums.amd.com/forum/messageview.cfm?catid=14&threadid=108319
It's because AMD's lack of information, apparently, that AsRock didn't list it.
I don't see the voltage range listed anywhere. (To include AMD)
http://www.cpu-world.com/CPUs/K8/AMD-Athlon%20X2%205800+%20-%20ADA5800IAA5DO.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103274
At any rate let's go with deductive reasoning, and see if this CPU is supported.
1) You can compare the Athlon 64 X2 5800+, to the other CPU's in the CPU Support List; that are comparable to it, and above it.
Don't even have to go too far.
Look at the ADA6000IAA6CZ, and the ADX6000IAA6CZ CPU's.
The two Athlon 64 X2 6000+ versions.
(Doesn't state that, just the above part numbers)
However I DO notice that the ADX requires BIOS version P2.00, and the ADA only requires BIOS version P1.60
(Since BIOS)
2) The motherboard chipset is an Nvidia GeForce 6100 and Nvidia nForce 430, Or Nvidia GeForce 6150SE and Nvidia nForce 430
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#For_AMD_processors
Compatible? Yes.
May need the P2.00 BIOS update, if not already installed.
Regards,
joecoolvette
SOURCE: brand new motherboard wont start up
Few things to check first:
a/ Are both power connectors from PSU to motherboard connected?
b/ Ise the PSU connected to the GPU?
c/ Have you tried monitor connector in both of the GPU ports on back of the tower?
Maybe those're daft questions but it's easier to start with the simple solutions :o)
erch
SOURCE: can asrock 775dual-915gl support dual core cpu?
sorry no prescott support only single core 3.0 ghz at new egg around 80 bucks but if you are looking to upgrade you can go a long way for cheap dmh1167 @ hotmail . com please let me know if you need help.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) /
Sempron with the new v6.0 BIOS and above. Processor interface via
2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
SOURCE: my mobo compatible w this cpu?
http://www.asrock.com/mb/overview.asp?Model=CONROE1333-DVI/H
CPU Support List,
http://www.asrock.com/mb/overview.asp?cat=CPU&Model=ConRoe1333-DVI/H
Intel Pentium D model 830, Smithfield Core, sSpec Number SL8CN,
http://www.cpu-world.com/sspec/SL/SL8CN.html
From all indications -> YES
Regards,
joecoolvette
[-> FOLLOW Anti-Static Precautions. A Processor is the most susceptible hardware component to Static shock.
Use good Thermal Paste,
http://www.hardwaresecrets.com/article/274
Testimonial: "thx joe and every one els who helped :) u guys are a big help i will try it and see what happens XD"
