Ricoh Aficio 355 All-In-One Laser Printer Logo
Rudy Diaz Posted on Mar 17, 2009
How I can reset that machine? - Ricoh Aficio 355 All-In-One Laser Printer
francis_smul
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 17, 2009
francis_smul
Contributor
Level 1:
Answers
Questions
Helped
1018
Points
9
Enter admin mode bij pressing the key button (right side of display) Once in admin mode goto help tools/utillities then press more and you will find the function Software reset.
Toshiba washing machine AW-A750SM error LED blingking power off
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website.
or try this link.
Reset Buttons for Washing Machines
or this link.
https://www.google.com/search?q=Toshiba+washing+machine+AW-A750SM+error+LED+blingking+power+off&rlz=1C1AVFC_enGB797GB798&oq=Toshiba+washing+machine+AW-A750SM+error+LED+blingking+power+off&aqs=chrome..69i57.606j0j8&sourceid=chrome&ie=UTF-8
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
How can reset my miele cva 620
To reset your Miele CVA 620 coffee machine, you will need to perform a "Reset Water Hardness" procedure. This will reset the machine's water hardness settings and clear any error codes that may be displayed on the control panel.
To perform a "Reset Water Hardness" procedure, follow these steps:
  1. Press and hold the "Menu" and "Coffee Bean" buttons simultaneously for 5 seconds.
  2. Release the buttons and press the "Menu" button again.
  3. Use the "Coffee Bean" button to navigate to the "Reset Water Hardness" option and press the "Menu" button to select it.
  4. Follow the prompts on the control panel to reset the water hardness settings.
After the "Reset Water Hardness" procedure is complete, your Miele CVA 620 coffee machine should be reset and any error codes that were displayed on the control panel should be cleared.
How to reset the samsung wa7584c1 + control panel
How to reset the samsung wa7584c1 + control panel my washing machine returns the 1E error and its not the pressure switch. when i bypass it works but wants to reset it. How do i operate the control panel to reset. please help 1.To reset the control panel of your Samsung WA7584C1 washing machine, you can follow these steps: 2.Unplug the washing machine from the power outlet. 3.Wait for a few minutes to ensure that any residual power is discharged from the machine. 4.Plug the washing machine back into the power outlet. 5.Press and hold the "Start/Pause" button for approximately 5 seconds. 6.Release the "Start/Pause" button once the control panel lights up or resets. Check if the error code (1E) has been cleared. If the above steps don't work, consult the user manual of your washing machine for specific instructions on how to reset the control panel or troubleshoot the 1E error code. If the issue persists, it may be necessary to contact Samsung customer support for further assistance or to schedule a service appointment.
Reset answering machine
A good first step would be to go back to your first post and add a comment specifying the make and model of your answering machine. Different machines have different reset procedures and no one can tell you how to reset yours without knowing what you have.
37helpful
Reset Fisher and Paykel washing machine
HOw to reset the Fisher Paykel machine. Mine one keyborad working but machine doesn't function. Where is reset button please?
3helpful
2answers
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
3helpful
3answers
Reset Xerox Copier Machine model No. 5825
your copier should be displaying a fault code, different codes need different reset codes - be specific
Top Ricoh Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
