The tecs installed a 56 orfus instead of the manufacturer preset 55 to solve a noise problem when the stove was heating. Should I be worried it's too big and there will be gas leaks? Or will there be any problems in the future?
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
SOURCE: Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
SOURCE: Propane gas burner now has red flame instead of blue
Hi, If you have the same problem with your stove , furnace and water heater, Then you look for things in common that would cause the problem. Any change in the flames is an indication of a change in the fuel/air mix. The item that would be common to all would be the pressure diaphragm. This is not something a customer should work on without a through knowledge of how they work. I think you would be well advised to have a service call. Good Luck!
SOURCE: GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
