Rock & Ice Climbing Logo
marc alaniz Posted on Apr 11, 2013
Need to tie a knot. - Rock & Ice Climbing
gbauman01212
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 11, 2013
gbauman01212
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
595
Points
8
Wrap rope over itself back up and through the hole and pull both ends need more knot repeat but be careful to center new knot to exisisting knot
2answers
I want to know a bit more about the various knots you can tie, which ones are the best and strongest?
I'm not the best at tying knots, but have a look here:
Fishing Knots Fly Fishing Knots Knots For Fishing Fishing Line Knots How... they have some amazing knots on there for fishing, hope that helps.
Apr 23, 2015 • Garden
2answers
How easy is it to use a Tie Fast Knot Tying Tool?
Hi - I have one of these and just some practice is all it takes. I bought a spool of cheap line at the local store to practice with.
Not hard to learn and makes great nail knots and hook snells too.
Regards - Fred
2helpful
4answers
How do I make a knotless knot
I assume your using wire cable. Termination ends are available and a special set of pliers are required.
Sep 28, 2014 • Fishing
Knot tying instructions/yarn
tie the knot with a reef knot then thread any spare yarn through the side of your squares.
Where can I learn to tie rope knots like some sailor knots?
You can do a little searching online to find tutorials for tying sailing knots. If there is a specific knot that you are looking for I would suggest going to Wikipedia to see the list of knots and then look YouTube or a site like eHow for step by step instructions for how to tie them.
List of knots Wikipedia the free encyclopedia
I have a 1200w ust portable generator and when I went to start it the cord it the cord snapped. What tools do I need and how do I replace it?
You do not need any special tools but you do need a third hand somtimes to complete the job.
Here are the basic steps after you remove the starter from the engine:
Prepair the new starter rope by burning the end to keeping it from fraying and shape it into a point. Use a rag to shape the point because it will be very hot. (about 5 feet of good qualty starter rope size to match existing. It is sold in sizes form about 3.5 to 6.5) Tie a temp knot on the other end of the new rope. Remove the old rope and align the hole in the spool with the hole on the starter cover and practice incerting the rope thru the guide hole on the cover into hole on the spool . This will be the final action after you wind the spool. You should be able to hold the spool and insert the rope thru both holes and tie a knot while holding the spool in a wound state. Once you have mastered incerting the rope thru both holes and tying a knot you are ready to begin.
Wind the spool in the same direction that the spool turns when you pull the rope. You must wind in the correct direction or you may bend the rewind spring out of shape. The spool will begin to tighten as you wind and will eventually stop turning when the spring is fully wound. Once fully wound unwind spool one full turn and stop when hole on spool aligns with hole in cover. Now insert rope as practiced thru both holes and tie knot with free hand or have helping hand. Once knot is tied slowly let spool take rope in untill no more will go in or you reach temp knot. Now tie pull handle and you are done. Good luck
Top Rock & Ice Climbing Experts
john h
Kolbrun...
Explosive Fireworks
Explosive Fireworks
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
