Optics Logo
A
Anonymous Posted on Apr 08, 2013
Scopes The elevation turret on my scope is loose ... it is an older scope , a Simmons Whitetail Classic 1.5 - 5 x 20 , made in the Philippines , is it worth repairing ?
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Dec 15, 2008
SOURCE: SIMMONS 3X9X32 BLACK RIFLE SCOPE
check to make sure it hasn't turned in the scope rings. I am sure if it is somewhat new simmions will fix as long as it falls within warranty
Anonymous
  • 81 Answers
  • Posted on Jul 21, 2009
SOURCE: I'm looking for a manual or instructions for a
your best bet is to locate your local shooting club and ask someone experienced with specialist scopes. As for now, all I can suggest is to sight the scope in at 3x power. I'm not sure about a boresight on this scope, since is is at the extreme budget end of zoom scopes. If you mean it has a rangefinding (or ballistic) reticle, then you might try here: http://www.perry-systems.com/reticle_analysis.htm for basic usage guide. The reference distances will vary according to several factors, including but not exclusively: bullet weight, muzzle velocity, firing angle, windage adjust, wind direction.
Anonymous
  • Posted on Oct 16, 2009
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Anonymous
  • 2702 Answers
  • Posted on Nov 18, 2009
SOURCE: my simmons scope cross hairs have turned diagnally
it is repaireable but its going to cost more that a new scope,, your one has shook its self apart,, to fix it it needs to be striped right down all the glass will need to be cleaned and after the repair it will need to be refilled with gas,,,,so its not worth the cost of a repair,,sorry
Anonymous
  • 2702 Answers
  • Posted on Nov 20, 2009
SOURCE: I have a 25 year old Redfield 6X18 scope, with an
bullet drop compensation,,,,compleat hog wash!
no such thing in a scope, only a realy pricy one like £1500.00p worth and there not that good! but there coming soon! driven by a lazer for range finding,,,
still your scope has clouded up becouse its leaking
water has got into it, it could be repaired but its not cheap to do, it needs a complet strip down all the class cleand and new seals then a re-gas and it should be as good as new for another 25 years or so,
any good scope with mill dot will work for you, you just need to relurn the bullet drop over again,,and with the years of shooting you have had that should come easy as falling over,,,why not just get a good prised 3/9x40 mill dot and try that out insted, you will be plesently pleased with todays mid priced range scopes treet your self, and save money at the same time
Testimonial: "Both Leupold & Nikon DO have bullet drop compensation reticles, which are similar in principal to the mil-dot. The BDC scopes are becoming very popul"
Top Simmons Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Simmons Optic Expert? Answer questions, earn points and help others
