Lands Phones Logo
A
Anonymous Posted on Apr 04, 2013
RTC failed on ep802 - EnGenius Lands Phones
NE56R31U Gateway No bootable device
old gateway , now owned by ACER.com
the old Gateway in Seattle went BUST.
yours 2012 made, not too old, and is ACER for sure inside.
here is the list of top fails, and cures.
1: remove the big battery and test PC, run ok now, on AC only.
it must even forever.
2: replace the RTC coin cell battery at 7year max old. (its time)
3 ;the HDD is bad. we run HDD tests on it now., in this order
learn that if the RTC bat. goes dead the NVram forgets
and with NVram forgets the BIOS can find the perfect HDD.
that is why ORDER matters. for that reason.
if after replacing any RTC bat. we go in to BIOS and reset BIOS to defaults inside BIOS, then make sure boot order inside BIOS
shows, HDD 0 first. and is not missing, if missing HDD may be dead. HDD can fail in 5 years on cheap laptops. and for sure bumped or dropped.
How fix non-systen disk or disk error
classic 2007 failures old PC ran for 7 years and died
as most did, all do really at 7, or nearly...
the cause is 3 fold. (1,2,3) Besides kids playing bad.
1: bad RTC coin
2: bad HDD (we run smart test on it prove this is 15 seconds work)
3: infected OS HDD,
7y is max life on RTC coin cell , 6 steps in free manual
page 72
http://h10032.www1.hp.com/ctg/Manual/c02834030.pdf
there it is and sold at wal-mart exit lane 15, for a buck $1 USD
cr2032
if you'd looked in bios. the hdd is missing in boot order or not there, RTC coin dead, is first but most of these old laptops
the HDD can in fact fail hard at only 5 years old. (avg)
6 steps to reach coin then 9 steps after to get settings right
after
https://www.pcdied.com/cmos.html#Reset_only
1helpful
My hp pavillion dv7 keyboard lock lights keep flashing; at one point the computer didn't want to boot up; I finally got that up today after six months. But the cap lock and the number lock lights still...
those are POST code, error codes, you need to watch time and count them. report them.
leave the battery main out.
does it run ok now? yes/no.? main battery out?.
even new cheap batteries fail easy and hard and short out.
test it with no main battery. it can run on AC power for ever.
are you going to run the COIN cell RTC battery for 10 more years.
it wont make it..
this PC is 10 years old today (can be) so is RTC battery end of life. most fail in 5 to 7 years, says the pink bunny. (and is correct)
the manual shows how to replace it at the real HP Site,
fixya is not hp, not at all.
page 63 shows the way to the RTC
http://h10032.www1.hp.com/ctg/Manual/c01918142
if you power on the PC, and hammer the f10 key]
BIOS runs, its menus;
check the time and date here, if wrong the RTC battery is dead.
read page 3 how.
http://h10032.www1.hp.com/ctg/Manual/c01662442
  • old PC have many points of failure (endless it seems)
  • does the fan run? is it packed in lint, as all are this old.?
  • causing it to overheat?
  • RTC coin cell bad.
  • main battery bad. (just leave it out until the PC runs right again)
  • power pack wires broken, or running real hot.
  • HDD going bad,
  • windows infected?, no OS stated but avoid XP.
HP caps lock POST blink code page is a horror of horrors
no 2008 listing, to name one flaw (2011 and newer sadly)
https://support.hp.com/us-en/product/hp-pavilion-dv7-1100-entertainment-notebook-pc-series/3756677/model/3807256/document/c01732674
here is a old post at HP, one guy 3 year ago said
LEDs blink 1 time
CPU
CPU not functional
LEDs blink 2 times
BIOS
BIOS corruption failure (RTC coin cell dead)
LEDs blink 3 times
Memory
Module error not functional
LEDs blink 4 times
Graphics
Graphics controller not functional
LEDs blink 5 times (or RTC dead)
System board
General system board failure
LEDs blink 6 times (or RTC battery dead)
BIOS
BIOS authentication failure
3helpful
3answers
Bad chip rtc please reboot
Error cannot be resolved. The internal memory is failing.You can try a powercycle about 5 to 25 times in a row. Powercycle is removing the power cord and plugging right back in to the terminal. RTC = Real Time Clock, cannot be fixed, replacement device will be needed if the powercycle option does not work.
5helpful
2answers
Bad rtc chip please reboot
RTC is the Real Time Clock or the Modem within the terminal. This error means that the device is failing and would need to be replaced at some point. To resolve you would need to powercycle many times in a row until the screen with show "TAMPERED", then it will go to the Sale, Refund, Void screen and you can run transactions. This error will arise in the future. RTC error cannot be resolved for good. Thank You!
43helpful
5answers
Verifone vx 510 bad rtc chip please reboot
verefone the terminal has a problem in the display shows bad rtc chip, as I can compose for it functioning properly again?
Password was changed unknowingly by child.can't get in! Acer laptop
1~try to download service guide of your laptop.
2~learn how to reassemble the laptop.
3~ find the the location of RTC battery.
4~take the RTC battery off and wait 10 seconds.
5~put the RTC battery back to the RTC socket
NOTE:
1~BATTERY POSITIVE SIDE DOWN
Were is the rtc can you show me a pic of the rtc
RTC stans for Real Time Clock. It is the chip that keeps the time in your computer and the beat, so to say. It keeps working even when the computer is down. It has an indepent battery.What do you want with it?
Hope it helps.
M2V Replacement failing to post after initial power on
is the keyboard operational? also try another video card and finally remove the RAM just to POST.
Top EnGenius Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
