FCC ID:PRIRM-237
Hi, You can get the accurate restriction code for your Nokia 3110 Classic from www.mobileunlocksolutions.com at affordable cost with easy unlocking instructions. Good luck.
SOURCE: 3110c
call ur customer care (aircel,airtel...etc)...then give ur last 4digit number of ur sim card ...after tat they ll give ur puk code...used tat code and open ur security
SOURCE: undo restriction code nokia 6500s-1
NOKIA UNLOCK AND OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software
Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI
number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to
obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this
power saving feature "SIM Clock Stop Allowed", it means you will get
the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date,
4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To
exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
SOURCE: Asks for restriction code for nokia t-mobile 2610b
salut j*ai un nokia 2610 b l*horse que j*allumer il ma demande code de restriction svp envoyer moi ce code ce tel vien de usa et je veux utiliser en maroc merci. type rh-87 ic 661ab-rh87 imei:011673/00/355095/2 code:0565017hp204v
SOURCE: code de restriction de Nokia,
enter restriction code: nokia corporation type:RM-443 Model:6303c ic: 661u-rm443 fcc id:ppirm-443 0587468 IMEI:351505/04/805929/2 made in hungary
