Just phillips universal remote cl035a code for zenith tv
Phillips universal code for zenith tv Universal Remote Control Code Finder http://www.remotecodelist.com/ Codes for Universal Remotes Welcome to Remote Central Universal Remote Control Reviews More
Try these codes. 0738,0826,0284,0888,0000. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
SOURCE: codes for universal remote
here is a link to the users manual.
http://www.p4c.philips.com/files/s/sru3003wm_17/sru3003wm_17_dfu_aen.pdf
SOURCE: i have a philips universal cl035a remote.i need
In the manual it say's that what you need to do is hold the code search button untill it stay's steady then press the function button (TV, cable or whatever) for the device you need to program before doing this though turn the TV or whatever on first. Then go to the chanel select up or + button and continue to press it until it changes channel if you over shoot it you can press the - or channel down button.
When you are were you want to be quickly press the mute button and release ( warning do not hold the mute button just press it quickly and release.) This will set the remote to the corect code.
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
