Kitchen Appliances - Others Logo
Will Pascall Posted on Mar 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to replace element
Trying to change an eliment
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Mar 06, 2013
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
316145
Points
2196
This shouldn't be hard. Just remember to put element back the same way you took it out.
Replace heating eliment in 26" Amana TTW airconditioner unit ?
it will be the thermal fuse for sure
its a small metal cylinder usualy around the heating element
with two connections
2answers
Replaced thermostat and heating eliment still not heating up dryer runs and blows ari just not heating up.
ALWAYS UNPLUG DRYER BEFORE CHECKING
1.loose wiring---check terminals & wiring
2.defective centrifugal switch in motor---replace switch (check linkage to motor
3.defective timer---replace timer
4.open heater element---replace heater element
2answers
Dryer does not get hot, already changed the heating eliment
this might help
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Feb 15, 2010 • Dryers
1helpful
Free standing kenmore dryer series 90 floor model not stacked not drying
Could be the heating eliment..
A way to check it ---
remove the exaust hose..
Put a mirror to the exaust hole trying to see inside to the eliment(s)..
When running - the eliment should glow hot..
If its not - it migt need to be replaced..
Hope this helps !!
rate me good ;o)
Will I get power to both elements at one time I test power at elements while unit is heating and can only get power to one element at a time.When one thermostat cycles off the other element will come on.I...
You are correct. That is the way most of the two eliment  water heaters work, one eliment at a time. Make sure that the two thermostarts are set at the same value. Have you tried just making the water hotter, so that the hot water will not be used at such a fast rate, when mixed with the cold? Also draining the sediment from the bottom of the tank with increase the water capacity,of course.
Black wire to eliment burned off running on one eliment
Hello, You can try re-terminating the connector with a crimp on style connector. Just make sure the wire going to the element is in good shape. If the calrod heater element has shorted out it may burn the at the connection again. If not, you have fixed it! Good luck...gary
3helpful
2answers
How do you know if it is the element that is bad or the therm-o-
Disconnect the electric for the unit. Disconnect the two wires from the two eliments. Place a battery type test light or Ohm meter is more conclusive if you have one, Light should light when placing the two test leads to the two eliment contacts(while they are disconnect for the water heater wiring) should be dim but glowing. If no light the the eliment is open. If an Ohm meter the Wattage is written on the heater the heater. E=IR P=IE. It should work out to about 1200 -1400 ohms if 220 volt heater. If the light is bright just as if you had put the two test leads together,then you can say that the eliment is likely shorted. Either no light or a Very bright light requires the eliment to be changed.   To check the thermostats, Raise the ajustment one one at a time, until it clicks. Listen for the heater to be heating. Turn that one back down and do the other one the same way. I hope I have been clear enough. About one gallon of water should be drained for the bottom of the tank once a year along with checking the preasure/tempature safety relief valve by  operating it ,using the leaver,for  a few moments as preventive maintenance.
2answers
Eliment
Did the top element ever work? Perhaps it only works in "broil" setting.
hamar nnelg
Top Dualit Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
