Balboa Instruments BALBOA VS500Z  PUMP , LIGHT, OZONE - 54219-Z Logo
Anonymous Posted on Feb 25, 2013
Variable error codes and shut down
Bought the replacement vs500z unit a few months ago. Ever since install it consistently gives one error after another, alternating between overheat HH, and OH(when it is not) and sensors out of balance Sn, and most of the time HL. The first few days it was dr and dy. I assumed it wa a priming problem, then it would run fine for few days, then dr and dy again. I shut it down for a couple of months for winter, and restarted it yesterday. It heated up fine and ran without error for 1 day, and now it reading OH, HH, and Sn again. Failing to heat on its cycles, then overheating and shutting down. I am not setting the temp above 102. Whazzup????
4 Related Answers
Ian  Hot Tub
hot tub plus
  • 77 Answers
  • Posted on Apr 01, 2010
SOURCE: When I change the temp. setting it keeps heating at original temp
The keypad appears to working correctly.
When you alter the set temperature via the keypad the display will flash the temperature thats to be acheived, once it stops flashing the keypad will revert back to the current temperature of the water.
Hope that helps,
Ian.
http://hottub.synthasite.com
Ian  Hot Tub
hot tub plus
  • 77 Answers
  • Posted on May 22, 2010
SOURCE: just installed new heater - error code sns -
Assuming that there are no air-locks and the pump is running ok....
Check the sensor connections on the PCB and make sure that they're clean and secure.
If the fault persists, (with the power turned off) you will need to remove the sensor connections and test the resistance of the sensors with an ohm meter. They should read the same. If they're different you will need to replace them.
Regards,
Ian.
Anonymous
  • Posted on Jul 19, 2011
SOURCE: I have the Balboa 500Z pump heater kit. Its hooked
I have a 6 month old Balboa 500Z. I have noticed that the filter system tis running all the time 24/7. I have reset the filter cycle to run for 2 hours { F2 }. It still is running all the time. It dose not seem to make a difference what I set the cycle for it just keeps running
balboadirect
Bath and Spa Parts Online
  • 47 Answers
  • Posted on Sep 12, 2011
SOURCE: I have a balboa spa
It is possible that the board is bad. A loose connection orlow voltage issue may also cause this problem to occur. If the voltages arewithin the acceptable rand and all connection are tight then remove any accessoryequipment and restart the unit to see if the problem continues. If it does thena new board will probably resolve the issue.
You can find answers to common spa problems online at http://www.balboadirect.com/support.aspx
Hope that helps!
Top Balboa Instruments Pool & Spa Experts
Bath and Spa Parts...
Anonymous
Are you a Balboa Instruments Pool and Spa Expert? Answer questions, earn points and help others
