Hardware & Accessories Logo
Paul L Cristofori Posted on Feb 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i program a tork dtu40 timer
New Tork DTU40 timer came with no user manual. I found how to wire it, now I need to program it.
Gene Haynes
Level 3:
  • TORK Master 5,391 Answers
  • Posted on Feb 18, 2013
Gene Haynes
TORK Master
Level 3:
Answers
5391
Questions
0
Helped
2659358
Points
14125
1) Copy following link for programming manual and wiring Tork DTU40 40amp timer.
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
2) The timer mechanism is old Intermatic/Grasslin/GE discontinued model, and then newly re-minted by Tork in 2012. Timer has 1 year limited warranty against defects in workmanship. This timer is protected from surge by the reset feature, but can burn out in heavy surge event. Non-replaceable Internal rechargeable battery retains programming until timer is reset. Always reset new timer to delete trace memories.
3) This timer can be wired many different ways, and timer automatically detects voltage, so there are no dip switches to set. Timer must be wired before power is turned on. Do not spark-test across terminals.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
5 Related Answers
Anonymous
  • 232 Answers
  • Posted on Oct 14, 2009
SOURCE: I need an instruction manual for the Tork 1101
go here:
http://www.weisd.com/store2/TOR1101.php
click on the wiring diagram
Anonymous
  • 3 Answers
  • Posted on Oct 23, 2009
SOURCE: NEED INSTRUCTION MANUEL FOR TORK DZS 100 TIMER
contact tork @ 888-500-4598 they can get you one and it may be available online at their web site??
Anonymous
  • 760 Answers
  • Posted on Aug 03, 2010
SOURCE: Not sure how to wire my Tork 1103 timer
The L terminal would be for your "hot" incoming black wire. The X terminal would be for your load outgoing black wire. Connect both white neutral wires to the blank terminal (notice this feeds the timer motor. The other two terminals (1&2) are not necessary if it is a 110V single circuit.
A
Anonymous
  • Posted on Oct 13, 2010
SOURCE: I need an instruction manual for programing a Tork
http://waterheatertimer.org/pdf/TORK.DG100.120.INSTALL&OP.pdf
Tork DG100 7-day single channel digital controller
125 Volt clock motor
NC and NO poles
A
Anonymous
  • Posted on Jan 23, 2011
SOURCE: wireing a tork clock timer
Following link shows Tork timers and manuals, with wiring diagrams:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Top TORK Hardware & Accessories Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
