Clothing Accessories Logo
A
Anonymous Posted on Feb 11, 2013
My samsung glaxery 2 tablet it won't come on
I charged the tablet but it won't cme on. ipressed the power button it is not on.
5 Related Answers
Logicl77
  • 17 Answers
  • Posted on May 14, 2011
SOURCE: my little buddy won't turn
I have 2 of these devices. Try using a cellular phone charger with the same plug at the end and plug it in. I have waited 5-10 minutes after doing this and they have come back to life and turn on. Maybe it will work for you.
Lewis
Anonymous
  • 1157 Answers
  • Posted on Jun 17, 2011
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
TechyDrood
Justin
  • 2072 Answers
  • Posted on Oct 16, 2011
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
Priyesh Vadher
  • 547 Answers
  • Posted on Jul 02, 2012
SOURCE: my tablet won't come on I've had it charging so the battery should be full is there something I can do?
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
mobil master
Computer Repairing
  • 14641 Answers
  • Posted on Aug 28, 2012
SOURCE: vizio tablet won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Top Clothing Accessories Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
john h
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
