How tosavedata Tosavedata, use softwarefullversion, for example,youcan useEASEUSData Recovery.After the data issaved, do therepairflashdrive.
Repairflash drive Kingston 1.Right-click theflashdrive,selectFormat- selectquickformat.Ifthis does not work, don'trepeat,dothesecond. 2.Format fromAdministrative Tools. WinXP: clickSTART-ControlPanel-Administrative Tools-Computer Management-DiskManagement-right clickthe flashdrive-selectFormat-selectquickformat WinVista& 7: clickSTART-ControlPanel- selectViewby:Large Icons-Administrative Tools-Computer Management-DiskManagement-right clickthe flashdrive-selectFormat-Performaquick format-OK.Ifthis does not work, don'trepeat,dothe third process. 3.Formatusing thesoftware,the HPUSBDisk StorageFormat Tool.Make the processquickformat.Ifthis does not work, don'trepeat,dothefourth. 4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system Win XP: double click the file cp006049.exe - select Install Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
I was also occuring from same problem. Do the following steps:-
1. Right click on my computer icon and open manage.
2. Then open disk management.
3. There u see ur pen drive.
4. Right click on ur pen drive and click on format.
5. After successful formating restart ur computer.
6. Ur pen drive wil work again.
other method pen Command Prompt, click Start, click Run, type cmd, and then click OK
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
Scan the pendrive for virus infection, that may be the possible cause.Or try formatting it once and then check again if you cannot fix it using a antivirus.
If you are unable to open it ,there might be a virus in you flash drive which is causing problem . Solution: Select the flash drive and right click .now select autoplay, a dialogue box will appear ,now select open to open it.. if you are unable to do this . open my computer ,in the address bar ,click on the downn area button in address bar and select flash drive to open .if this also fails you have to format the flash drive .. Try this in other pc if you are unable to do this on your computer ..now if you are getting same problem ,format it. right click on it >select format >and format it to remove virus ... --------------------------------------------------------------------------------------------------- If this answers your question please rate this as fixed. THANKS.
