Error Code 610
Solution1: As the problem is with the Purge Unit, open up your printer and move the print head to the center. Disconnect all the power cables and thus look on the right whether the purge unit is fine and there is no piece of paper struck.
Solution2: Try resetting your Printer. Turn on the power button and thus press the Resume button for a good 15 to 20 seconds to reset your printer.
Solution3: Reset the cartridge. To do so, turn off your printer and open the printer door. Now turn on the printer and make sure the cartridge is moved back to the center. Close the door as it is done.
Solution4: Clean the print head. Take a small paper towel and wipe out all the plastic pieces inside the printer carefully without further damaging it.
Solution5: Look for a micro-switch that is most probably being pressed by one of the purge unit cams. Just clean it to get rid of the error.
You have not mentioned the model
This error code means that the dim is at fault or requires re-seating into the machine.
