Canon PIXMA iX4000 InkJet Photo Printer Logo
A
Anonymous Posted on Jan 28, 2013
Support Code : 1660 - Canon PIXMA iX4000 InkJet Photo Printer
What is Canon Support Code 1660?
It normally stops if you don't install the ink cartridges correctly. When the failure strick on your printer, it will not allow you to continue with the printing assembly. This error can even make the printing process quiet and stable. If you want to experience a hassle-free printing, then you should Resolve the Canon Printer Error Code 1660. First check the main reasons that cause:-
1.Inaccurate fitting of the ink cartridges.
2. Misplacement of the ink cartridges.
3. Cracked or closed ink cartridges.
4. If the print device is not possible to recognize the ink tank then you may view Canon Support Code 1660
Full Blog - Canon Support Code 1660
How can I resolve the Canon Printer Error code 1660?
This error message indicates that the ink cartridges have been installed incorrectly. Take the following steps to resolve the issue:
1. Lift Printer cover
2. Check to see if the red indicator lights are on or not
3. If a particular cartridge isn't showing a red light, it means it was installed incorrectly. Remove the cartridge and make sure it is installed correctly and the orange cap has been removed before installing the cartridge
4. Press "Resume" or "Cancel" to verify that Error Code 1660 no longer appears
CANON MX922 INK ERROR CODE 1660
There are various reasons liable for this error. If you want to exclude this error then you need to know the causes of Canon Support Code 1660. Some of the common reasons for this error are mentioned here:
1.Incorrect fitting of the ink cartridges.
3. Broken or clogged ink cartridges.
4. If the print machine is not available to recognize the ink tank then you may face Canon Support Code 1660
Solutions that Rersolves Canon Support Code 1660 Easily:-
Solution 1. Reinsert the Ink Cartridge - This is a very simple answer to solve your difficulty. By reinstalling the ink cartridge you can succeed this error.
Solution 2. Cleaned and reset the paint cartridges - If the above solution fails to remove this error then clean and reset the ink cartridges to fix this problem.
BLOG for Support- Canon Support Code 1660
Error 1660 on Canon ip4200
Canon Support Code 1660 shows a cartridge error.
It normally happens when you do not install ink cartridges correctly into the printer. As and when it shows error 1660 with your Canon machine, you will not be able to take the printing session more. Moreover, you will notice that the printing method becomes slow and sluggish.
Reasons that cause Canon Support Code 1660.
1. Ink cartridges are not installed properly.
2. Printers are unable to recognize the ink tank.
3. Inks cartridge may be damaged or clogged.
4. Misplacement of ink cartridges.
Don't get fear if you are also suffering the same position, you can easily fix this error by taking help from us.
Manual for a Bissell Powerlifter 1660
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell 1660 User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Replace N with a numeral that makes the sentence true 492-N=2152
492-N=2152
2152-492 = 1660
492-1660=-2152
492-(-1660)=2152
N= -1660
Need an instruction manual for older canister model. bissell powerlifter, model #1660
Ava B.
Nov 01, 2010 • Vacuums
4answers
My printer won't recognise the new ink cartirdges
Canon support code 1660 indicates a cartridge error. It usually occurs when you do not install ink cartridges properly into the printer. As and when it shows error 1660 with your Canon device, you will not be able to take the printing session further. Also, you will notice that the printing process becomes slow and sluggish. When your Canon Printer strikes with error 1660, you will notice that the orange light of your device will blink four times.
This error can even make the printing process slow and sluggish. If you want to experience hassle-free printing, then you have to troubleshoot the Canon support code 1660. If you are a Canon printer user and facing this problem on your device, just go through this article to fix this error quickly.
Some Reasons that make Canon support code 1660:
>>Improper installation of the ink cartridges.
>>Damaged or clogged ink cartridges.
>>If the printing machine is not eligible to recognize the ink tank then you may face this error.
Don't take tension while Canon support code 1660 appears on the screen. if you want an instant solution or Expert advice checks the mentioned blog.
3answers
Instruction manual needed for Whistler 1660
Pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
