ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775) Logo
Anonymous Posted on Jan 25, 2013
Replace backspace key - ASUS Eee PC 1005HAB Netbook - Intel Atom N270 1.6GHz / 10.1" WXGA / 1GB DDR2 / 160GB HD / Webcam / W... (884116027775)
  • Anonymous Jan 25, 2013
    ASUS EEE pc 1005hab backspsace key popped off and can't get it to stay on. Thank you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 25, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
33
Points
I lost my f key once i just glued it back on
How can I fix a backspace button that has stopped working?
Make sure no bred crumbs are stuck under the backspace key. You may need to replace your keyboard.
Backspace key
if the other keys are working, you need to check if there isnt anything underneath the key which could be physically blocking it to be depressed. let me know
How do I enable the backspace key to backspace and correct typos on my HP?
Nothing is supposed to be done to enable or disable, not that I know of. Possibly, your keyboard is the problem, which is very anoying.
2helpful
My backspace key does not work.my laptop is Dell Inspiron 640m. Thank you.
Your backspace does not work.... well could be many reasons, but if its the key itself, you can replace just the dell laptop key, if you spilled something then you will need a new keyboard, we really need more info. Good luck!
Inspiron 1525 backspace and H keys not working.
you can always ket a keyboard off ebay. depending on the model its for between $12 and around $20
The cover to my backspace key came off. How can I
The keys are pretty much snap on/snap off. If you can't get it to pop back on, then you will likely have to get a replacement keyboard. They are about $20 on ebay and take about 15 minutes to replace.
http://shop.ebay.com/i.html?_nkw=D630+keyboard+&_cqr=true&_nkwusc=D630+keyboar&_rdc=1
http://support.dell.com/support/edocs/systems/latd630/en/SM/keyboard.htm#wp1084976
Backspace key popped off
Replace the keyboard, the little frame underneath the key is bent or broken very easily. Replace the keyboard for $50 and move on...
1helpful
"lost backspace button on Acer Aspire One"
Unfortunately, there is no way to purchase just one key of the keyboard. Acer does offer full replacement keyboards and they are easy enough to install. Unless you can find just the backspace key on eBay or something, you might have to replace the entire keyboard.
Thanks for using the fixya Forums.
1helpful
Backspace button does not work
Use the backspace in between a sentance typed on Notepad, if that works - your keyboard and key is functional. Else, you might need a replacement Keyboard. (Click on Start > Run > Notepad > OK - To open notepad)
Top ASUS Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
