I had to unhook my battery, since then it doesn't work...do you know how i can reset my prostart or perhaps it's in "valet" mode?
I have a problem my light in the the antana stay on but wont flash and the car wont start either so how do i fix it
Yes I do , very simple. Insert the ignition key and rapidely move between accessory and off five (5) times . This replaces the usual bypass switch under the dash board.
EAGLEBOB
You will have to turn car off, open hood, inside you will find a hood pin switch, there will be a grey wire running to it from the firewall on your car, you need to turn the black plastic pin back and forth to mack sure it is making good contact, they are usually rusty, wait 5 sec after turning it back and forth, then hold the pin switch down for 4 sec, release (take finger off) and then press and release 1 more time, parking lights will turn on, then turn your ignition switch on then off, next hold the lock button down on your remote starter remote for 5 sec, you should hear clicking from under the dash usually 5 or so, hopr this helps
Have 2002 Hyundia Santa Fe, with Car pro alarm with no istructions on how it works or how to reset alarm car will not start
I had the same problem when I changed the battery int car , it wouldn't starte after withe the remote I tried to turn off the valet mode evrything showed ok but still would not start exept if I left the key into the ignition hole , so I disconnected the car battery again and reconnecked it , went through the the valet steps like turn the ignition key on an off 5 times Inside a 10 sec. lap time this should get the LED on the antena off or just blinking , if not repeat it again 5 times , it worked for me
Please email me if you find a solution as i am having the same problem and about to un-hook the whole thing and dumb it in the garbage.
zenon102@rocketship.com
I believe it is different for different cars. I had to replace my battery a few months ago, and it was automatically reset when turned the car on. I would suggest looking in the owners manual, mine told me what to do. Good luck!
<a rel='nofollow' href='http://www.autostylesplus.com/' >http://www.autostylesplus.com/</a>
secrity light blinks and the battery light is on all the time bu the car will not turn over. has new battery and new starter. will not go into gear. all lights work. what is the bypass for the security system?
Everything works except start mode, all I did was change the battery in the vehicle. "ProStart 3-in-1 Remote Car Starter with Alarm"
i have a prostart alarm system...tha power door locks and alarm work but when i try to start it tha starter turns for about 3o seconds and it sounds like it is running but it isnt running after its done....it trys 3 times...how can i fix this
installed a new battery and starter no longer works?
Is this a GM? Try leaving the key on the on pos for ten min. light should go off. then turn it off for 5 sec.
I have installed ct-3471tw with Dball2 on Honda Odyssey 2014, after I close the hood, I can remote start, and stop several times, and control the doors, but when I get into the car and put the keys in to drive off, and then turn the car off, the antenna LED stops blinking, and when I try to remote start, the parking light flash 10 times indicating that the hood was open, but it was not. I already checked to make sure the hood switch wire does not make any contact to ground. Any ideas what could be wrong? To remote start again, I have to release and press the hood switch again (open and close the hood) TIA
